Teamwork & BIMcloud
Comparison of models between teamwork projects
Javier Alvez
I want to compare my model with another one that is in bimcloud, but the entire list of projects appears grayed out, grayed out, disabled. What should I do to enable the projects and be able to choose one?
4 REPLIES 4
Just an idea: Do you have the necessary Roles and Permissions in Teamwork?
Sefa Yakut
any update??
Hello Laszlo,
I have same problem. I cant select my BIMCloud Projects. I can only select .pln files uploaded to BIMCloud. I have all permissions and I am a server admin.
Sorry, I cannot check, I do not have BIMcloud running on my machine.
Do you have access to the BIMcloud project (as defined by the Project Admin)?
Maybe you need to join a project before you can do the model compare (I am just guessing here).
