2024-04-13 02:55 PM
I want to compare my model with another one that is in bimcloud, but the entire list of projects appears grayed out, grayed out, disabled. What should I do to enable the projects and be able to choose one?
2024-04-16 12:50 AM
Just an idea: Do you have the necessary Roles and Permissions in Teamwork?
2024-09-04 11:27 AM
any update??
2024-09-04
03:03 PM
2024-09-04
10:53 PM
Hello Laszlo,
I have same problem. I cant select my BIMCloud Projects. I can only select .pln files uploaded to BIMCloud. I have all permissions and I am a server admin.
2024-09-04 10:56 PM
Sorry, I cannot check, I do not have BIMcloud running on my machine.
Do you have access to the BIMcloud project (as defined by the Project Admin)?
Maybe you need to join a project before you can do the model compare (I am just guessing here).
