Teamwork & BIMcloud
Embed .lcf in Teamwork File
Chris Grantham
Is it possible to embed an .lcf in a teamwork file or just individual objects? When ever I try to add the entire .lcf, the "open" button is grayed out. I can extract the container, and embed objects that way it seems to break the object or at the very least limit it's functionality. I would rather not add the library to the BIM server as it is project specific. Thanks in advance!
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
1 REPLY 1
You can load the project-specific library as a Linked Library, then select this library in the Library Settings Dialog and click the Embed placed objects of selected library button. All placed elements within the library will be added to the Embedded Library:
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/configuration/libraries/embe...
