How to unshare a project?
I just finished a shared project. I want to save it as a pln/pla on a back up server. I'd want to remove the project from the shared directory and basically unshare it. How do I unshare a project?
Eduardo Rolon
You would do a save-as (pln and/or pla) from the server and after verifying that the new files are correct then you would open "Bim Server Control Center" in the computer that is hosting the BimServer and delete the TW file there.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks, got it!
