I just finished a shared project. I want to save it as a pln/pla on a back up server. I'd want to remove the project from the shared directory and basically unshare it. How do I unshare a project?
You would do a save-as (pln and/or pla) from the server and after verifying that the new files are correct then you would open "Bim Server Control Center" in the computer that is hosting the BimServer and delete the TW file there.
Eduardo Rolón AIA NCARB AC28 US/INT -> AC08
Macbook Pro M1 Max 64GB ram, OS X 10.XX latest another Moderator
