Gus
I-m not getting pop-up messages from teammates in teamwork
Can anyone think of any reason that I wouldn't be getting pop-up messages from my teamwork teammates? I do get the message in the teamwork and I do get a very small notification in the bottom bar of the ArchiCAD window. I just don't get the regular pop-up which is really the only thing that gets my attention. Any thoughts about why this may not be working?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
12 Replies 12
Yvonne
Is this still an issue?
The pop up does not appear even when "Show New Message Alert in Teamwork" checkbox is checked.
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
Noemi Balogh
Depending on your OS, try this:
Windows:
0. Close all running ARCHICAD instances
1. Go to Registry Editor (regedit)
2. Go to Computer\HKEY_CURRENT_USER\Software\GRAPHISOFT\ARCHICAD-64\ARCHICAD-64 22.0.0 INT R1\Mail Bubble - replace 22 and INT according to your own version
3. Delete the New Mail Notification Rectangle registry key
4. Restart ARCHICAD
macOS:
1. Go to /Users/<username>/Library/Preferences/ Note: user Library is hidden by default. Press Alt when you click on the menu item "Go"
2. Open AC-64 22.0.0 INT v1.plist with a text editor, which is not formatting text (e.g. Sublime Text, MS Visual Studio Code) - replace 22 and INT according to your own version
3. Delete the New Mail Notification Rectangle and the <string> line under it (see attached screenshot where we marked what to delete)
4. Save the file
5. Restart ARCHICAD
Noémi Balogh
Staff Community Expert, Admin
Rubi06
Thanks Noemi,  I was having this issue, but it is solved with your solution
