2015-10-23 07:44 PM
2021-11-19 03:03 AM - edited 2021-11-19 03:03 AM
Is this still an issue?
The pop up does not appear even when "Show New Message Alert in Teamwork" checkbox is checked.
2021-11-19 10:48 AM - edited 2021-11-19 10:49 AM
Depending on your OS, try this:
Windows:
0. Close all running ARCHICAD instances
1. Go to Registry Editor (regedit)
2. Go to Computer\HKEY_CURRENT_USER\Software\GRAPHISOFT\ARCHICAD-64\ARCHICAD-64 22.0.0 INT R1\Mail Bubble - replace 22 and INT according to your own version
3. Delete the New Mail Notification Rectangle registry key
4. Restart ARCHICAD
macOS:
1. Go to /Users/<username>/Library/Preferences/ Note: user Library is hidden by default. Press Alt when you click on the menu item "Go"
2. Open AC-64 22.0.0 INT v1.plist with a text editor, which is not formatting text (e.g. Sublime Text, MS Visual Studio Code) - replace 22 and INT according to your own version
3. Delete the New Mail Notification Rectangle and the <string> line under it (see attached screenshot where we marked what to delete)
4. Save the file
5. Restart ARCHICAD
Noémi Balogh
Staff Community Expert, Admin
2022-06-22 02:00 AM
Thanks Noemi, I was having this issue, but it is solved with your solution
