Teamwork & BIMcloud
LAYOUT 90 degrees
while working in teamwork.. all layouts have turned 90 degrees (look at the image) and i dont know how to reverse them..
why did this happen?
7 REPLIES 7
Check the Master Layouts.
They must have been rotated 90 degrees somehow.
Can you rotate them back to normal?
only the layouts were rotated.. not the masters..
when i added another layout.. it fixed..
however.. thats something that shouldnt happen right? there's no way to rotate the layout as the floor plan right..?
Yes, this is strange behavior.
Similar thing happened to me. See my post "Skewed Layouts"
Adding a layout fixed it! Masters were not rotated, and neither were any of the views.
Very odd, at least now I have a work around. I was completely stuck.
Achille Pavlidis
Same here... actually even better... on a teamwork project one team member sees the layouts fine, and the other has them all rotated 90 degrees...
nice huh?
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
nice huh?
Same here, too! My team member computer shown rotated layouts while mine were fine! I tried with "creating new layout" but it didn't even work! Working around and it's back to normal suddenly! Don't really know why!!!
Keep learning new things everyday!!
Same just happened to me. After crashing my ArchiCAD 17 I reopened the recovered teamwork project and my layouts were rotated. The angle seemed to be corresponding to the angle of one of my viewsets.
Adding and opening a new layout solved the issue.
Very strange...
