archigreen
NO UNDO WHILE MORE THAN 1 PROJECT OPEN ON TW AC13
When I'm working with 1 project only everything is just fine. The Problem with the "UNDO" not being able is when I'm working with more the 1 project at the same time. Then the second project doesn't allow me to "UNDO"
And it Crashes when I attempt to drag multiple copies of an object.
Does anybody have a clue to find a solution?
Thank you in advance.
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
10 Replies 10
archigreen
AC 14 is doing great with this issue.
No problems working with multiple projects on TW @ the same time.
Cheers!
ArchiCAD 26
MacOS Monterey
64 GB
