bharat_hs_nct
Reserve elements as a set and name the set.
Hello All,
I've read some fo the Teamwork functionalities like reserve and release for one of the project requirements. The requirement is to list the expected elements which belong to their respective reserve set(like Workset in Revit).
Revit has a feature called Workset where you can assign a number of elements to workset and others to another workset. So we are finding if the element belongs to its assigned set.
There is Reservation Results window but it only shows all the elements reserved for the user, not any set or group. (refer: Reservation Results (Teamwork) | User Guide Page | Graphisoft Help Center)
So I wanted to check in ArchiCAD if we can reserve a set of elements and name the set. (also number of sets)
1 Reply 1
MSDC
Something like this would be great
