Previously in archicad 9 TEAMWORK all I had to do was blow away the LCK file if someone didn't sign out properly the night before and go in as administrator and force sign them out. Now I have encountered something resembling a corrupted file because it loaded the libraries but stop half way through the bar going across the sign in box (loading sign-in dialog box if this helps)
Now the question:
Is My file corrupted or is there some other way to sign in.
Already tried copying the file and opening it as a solo-project. Same result.
