Static IP Address for BIM Server
1. Is it absolutely necessary to have a Static IP Address for the BIM Server?
2. Can a work around be found with remote access through a VPN connection with a secured router?
3. Can anyone recommend the best Routers to use, either secured or unsecured?
All asked and answered dozens of times...
Go here:
http://archicadstuff.blogspot.com/
and search for "static ip"
or "vpn"
(Searching with the built-in forum search will not work with 3 letter or shorter terms, such as vpn or ip.)
No, you do not have to have a static IP. Yes, VPN can be a good solution for a number of reasons.
See also the various Wiki articles here:
http://www.archicadwiki.com/Teamwork
