Teamwork & BIMcloud
Task message VS text message
On page 28 of the collaboration guide, it talks about sending "simple text messages." How is this done? It does not explain how to do this, nor can I find it anywhere. I know how to send a "task message" through the teamwork palette, but the "text message" is supposed to pop up on someone's screen, not be inconspicuously hidden in the teamwork palette like a task message is...
Help?
12 REPLIES 12
Steven wrote:
It seems now though that even when I send a message through the normal channels (click send message in the teamwork palette), it will pop up on the team members screen for a few seconds, as well as show up in the teamwork palette. This is normal? Is the duplicity supposed to happen?
Yes / normal. The cool pop-up (fades in and stays translucent on Mac at least) is an 'attention getter' (and stays put if high priority). The message center in the TW palette is the permanent archive of all messages - you can read, archive, delete, respond with the buttons there. It is often the case that so many messages come at once that you may notice the pop-up, but still need to go through your TW inbox.
The element messages are similar, but happen when you request someone else's reserved elements or assign elements to someone else.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Got it Karl, thanks.
The following checkbox of the Work Environment Dialog controls whether these messages appear for you or not.
If it is turned off, they will not appear on screen, only in the Message panel of the Teamwork Palette. Not even the ones with high priority will appear in that case.
But it looks to me like it becomes effective only after I restart ArchiCAD. When I unchecked it I still the messages on the screen. After I closed and restarted ArchiCAD, it worked fine. That may not be the way it is supposed to work.
