‎2009-10-06 08:34 PM
‎2009-10-08 06:17 PM
Steven wrote:Yes / normal. The cool pop-up (fades in and stays translucent on Mac at least) is an 'attention getter' (and stays put if high priority). The message center in the TW palette is the permanent archive of all messages - you can read, archive, delete, respond with the buttons there. It is often the case that so many messages come at once that you may notice the pop-up, but still need to go through your TW inbox.
It seems now though that even when I send a message through the normal channels (click send message in the teamwork palette), it will pop up on the team members screen for a few seconds, as well as show up in the teamwork palette. This is normal? Is the duplicity supposed to happen?
‎2009-10-08 06:21 PM
‎2009-10-09 11:16 AM
