Werner R
Teamwork 14 File Size
Hi Anyone.
I need help please, we work on Archicad 14, still waiting to receive 15 here in South Africa.
Are there any restrictions in Teamwork File Sizes on the BIM Server? We do a lot of services coordination and use MEP as well. Our file is approximately 3.6GIG in size. We get a lot of crashes as well, will this be fixed in 15 or can someone give us advise. In 11, 12 & 13 we always split the file in hot links and had one master coordination file? will we need to do this again??
Can't wait to get my hands on AC15!!!
Kind Regards
Werner Reyneke
Werner
AC20, iMac 27" late 2012, 3,2GHz i5, 16GIG mem
OS 10.12.3
2 Replies 2
Werner,
The file size that you quote does seem to be quite large we have a coupleTW2 projects just over the 1Gig & they each have issues. Can I refer you to this thread http://archicad-talk.graphisoft.com/viewtopic.php?t=36322 as it is quite a good method for handling Large projects.
Werner R
Hi Wayne
Thank you very much for your reply, much appreciated.
Regards
Werner Reyneke
Werner
OS 10.12.3
