Eduardo Rolon
Unable to update BimServer 18 to 5100
I keep getting the following error:
"BIM Cloud detected the same version of BIM Server already installed on this computer. BIMcloud cannot be installed".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
12 Replies 12
problem solved here.
I had to activate my server through web browser using graphisoft ID
after that everything worked ok.
Steve Jepson
Problem solved for me too. I had to re-install the BIM Cloud so I could un-install it properly. Had to disable Services first. Ended up re-installing Windows 7 x64 completely, re-loading all system drivers...it was a 10 hour ordeal. Works great now. I probably did not need to do all of that but I am not a computer expert so I can only do things the hard way most of the time.
In any case, The BIM Cloud was a problem for me.
I just ran the Archicad 5100 update again (the first time I used it to update only archicad), but this time it updated the BIM automatically to 5100 version. And it works perfectly now!
