‎2003-11-20 08:08 PM
‎2006-11-01 07:04 PM
Matthew wrote:I agree. There's still some confusion that goes on. But eventually everyone will get it. Just like you said Matthew....through regular use and practice.
The main problem I have found with teamwork is that people are unfamiliar with the details of the workflow when it is only used occasionally. The biggest issue is that people forget to sign out since there is no reminder about this when you quit/shut down. Until GS fixes this it can only be managed by developing good habits, and these can (of course) only be developed with regular use.
‎2007-04-21 10:37 PM
TomWaltz wrote:We're just getting back into Teamwork (we went a couple of years with small projects that didn't require it). I would still recommend waiting until the CD phase to start sharing a project. You need it most at that time, and it's more clear where to divide tasks ("I'll take all the plans, you take all the layouts, and you take all the sections/details"). When you're "conceptualizing", the model is best placed in one designer's hands.
How are you handling creating new projects? Just sharing the project as soon as you do a "New from Template"?
‎2007-04-23 04:34 AM
Da3dalus wrote:Good point. It never occurred to me to use Teamwork for rendering but if people are doing it they should stop and do as you suggest.
I've also seen some make the mistake of sharing just to create renderings. If you're doing schematic renderings or animations, just open on different computers as "read only", and let them crunch. You can then save all of the movies and renderings to the same server, without the pains of Teamwork.
‎2008-03-18 05:38 PM
Matthew wrote:how did the process go?
It looks like time to breathe some life back into this topic.
At one of my clients we are implementing Teamwork as standard practice. I will be sure to post our experiences as we go along.
While we made this decision using AC9, it becomes even more important (and useful) in 10 with the PM integration.
BTW, Djordje; It seems to me that this topic might be more appropriate to "Working in ArchiCAD" or the "CAD Managers" forum.
‎2008-03-18 08:35 PM
Alice wrote:All files in Archicad start out as solo projects and theoretically you can share a project and later unshare it whenever you want. There's no reason to have separate templates for teamwork vs. solo.
i ask because we just completed (mostly) our first archicad project...which we tried to use teamwork with (probably bit on more than we could chew).
we're now taking a step back to work on further developing templates etc. an issue i have is that i believe teamwork to be useful, but some of the consultants we're in touch with tell us to use hotlinked files...i just feel like thats such a waste of the software.
a question: do you use seperate templates for teamworked files vs. stand alone files?
‎2008-06-09 11:54 PM
‎2008-07-31 04:42 PM
