Will running older BIM Server uninstaller remove current BIM
We have a BIM Server that has both BIM Server 19 and 20 installed. We have successfully transitioned to version 20 and would like to remove version 19. If I run the uninstaller in the BIM Server 19 folders, will it remove components needed by BIM Server 20?
1 Reply 1
Check this article:
http://helpcenter.graphisoft.com/technotes/bimcloud-and-bim-server/bim-server/migration-from-previou...
It says AC20 BIM Server is installed in a separate folder so I think uninstalling AC19 BIM Server will not affect the AC20 version.
