2018-08-31
01:24 PM
2023-05-09
11:44 AM
Noemi Balogh
2018-08-31 02:10 PM
2018-09-07 12:50 PM
2018-09-21 03:17 AM
2019-12-30 08:09 AM
2019-12-31 07:51 PM
gurmukhpanesar wrote:That takes some IT expertise. You will need to add a subdomain to your DNS registry (like bimcloud.mycompany.com) and point it to the IP address of your server, which must be fixed (or you can just access directly to an IP address). You also have to configure your router to route traffic to that machine, both inside and outside of your office (LAN and WAN). Sometimes your Internet Service Provider can help you set this up over the phone. However, you should also take network security into consideration (block ports that aren't required, runs firewall, etc.). Check out the BIMCloud help center online.
How do you set up the address for BIM Manager so that we can access remotely? Trying to figure this out.
2020-03-20 08:43 AM
2020-03-23 01:59 PM
Noémi Balogh
Community Expert, Admin
