2011-04-07 03:59 PM
The BIM Server is a multi-threaded application that from the start takes advantage of every core. Commonly a single core will be singled out for the bulk of one user’s ArchiCAD operations. Another user will end up being processed by a different core. The server will balance use across the physical cores. The more physical cores there are the better. A small office should use at least a dual core machine for its BIM Server. Although with the costs of quad cores so reasonable it is hard to justify not starting with a better machine.source:
From a BIM Server performance standpoint a 2 processor machine runs just as well as a single processor duo core machine.
2011-04-07 07:51 PM
2011-04-14 02:48 AM
