schagemann
bim server mac hardware requirements
dear all,
we are interested in your experiences regarding bim server mac hardware requirements.
we do run a couple of bim servers on mac minis, however it seems that there is only so much they are able to do as with e.g. around 10-15 users accessing around 20 files (approx. between 100 - 900 MB each) concurrently it seems that the current model mac mini (core 2 duo, 8GB RAM) reaches its limits.
also we are intriguied by the following quote on the archicadwiki:
The BIM Server is a multi-threaded application that from the start takes advantage of every core. Commonly a single core will be singled out for the bulk of one user’s ArchiCAD operations. Another user will end up being processed by a different core. The server will balance use across the physical cores. The more physical cores there are the better. A small office should use at least a dual core machine for its BIM Server. Although with the costs of quad cores so reasonable it is hard to justify not starting with a better machine.
From a BIM Server performance standpoint a 2 processor machine runs just as well as a single processor duo core machine.
source: http://www.archicadwiki.com/Teamwork/BimServerSpecification
so basically and as usual the more grunt the better - however we have also heard reports that running a bim server on a designated xserve with 32GB does not seem to run much smoother - really we are wondering were the sweetspot lies here.
so if you care to share your mac based setup and your experiences with it , it would be much appreciated.
ds.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
2 Replies 2
We have similar amount of users+projects and a
similar MacMini server but having only 4Gb RAM.
Everything running well.
A noticeable difference is in the file size; a typical team
file is well under 100 Mb and the biggest ones around or
less than 200 Mb.
In addition we have a remote 3rd party virtual server (Windows Server 2008) with much more humble configuration. That server is also having
around a dozen of projects sized 15...200 Mb. It works well
but I guess it occasionally gets more RAM than dedicated/paid for.
I wonder that keeping the file size down might be the key?
HTH, Juha
schagemann
juha,
thanks for your encouraging reply.
i agree that keeping file sizes down might be the key, which unfortunately is not always possible due to complexity of a project.
we are currently considering one of the following 2 options:
A. additional mac mini's, essentially distributing the load;
B. 1 x mac pro, hosting all projects;
from a management perspective the mac pro has obvious benefits (libraries, DNS setup, etc.), but the question remains if with TW2 a mac pro (more cores & RAM) will actually be able to provide any significant performance gains.
any thoughts much appreciated.
ds.
VKTRS | macinteract
