2024 Technology Preview Program
Teamwork & BIMcloud
lists and libraries in teamwork
Alex Moruzzi
I had a trouble with lists : no way to even create a list directory because teamwork said someone had booked the necessary libraries...
I found a way to re-create lists and one of the followings may be guilty.
- The external .pln content (modules) ;
- Shared libraries including the listings (the lists must be in the enclosed library of the project)
I don't know how it should be done but a small white paper about how to organise the shared libraries and how to import the listing schemes would be very beneficial for not wasting time...
Archicad 19 - OSX10.10 - MBP early 2011 16G/ssd
1 REPLY 1
Katalin Borszeki
Please add the following files to the embedded library in the Library Manager:
ArchiCAD_Library.lis
ArchiCAD_Library_COMP.txt
ArchiCAD_Library_CRIT.lic
ArchiCAD_Library_DESC.txt
ArchiCAD_Library_KEY.txt
ArchiCAD_Library_UNIT.txt
These files are located in the Application folder:
ARCHICAD Library 18\List Templates 18\Property Data 18\
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
