dhnguyen
remove deleted file
The file that's highlighted is already removed from the server, but it still shows up on this screen whenever I want to open/Join a teamwork project. Because It's corrupted, I cannot open it in order for me to remove the local data and delete it. Is there another option to remove it from the listing?
Thank you.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
3 Replies 3
dhnguyen
i found the answer. I wasn't able to delete this post.
DNguyen
ArchiCAD 18- 25
Eduardo Rolon
dhnguyen,
Post the answer and then I don't need to delete the post.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
dhnguyen
I have a very tough time posting anything in this forum in general because it takes 10 tries for me to log in to post something successfully no matter what browser i use.... so frustrating. and it has been ongoing for months (I'm constantly copying and pasting my response until it successfully goes through...
Teamwork> Project>Local Data Manager.
Go here and select unwanted file to delete it.
DNguyen
ArchiCAD 18- 25
