Teamwork & BIMcloud
Tips about Teamwork, plus BIMcloud functions and settings
Articles
File server capabilities came with BIMcloud 2020.2 and this feature allows you to store frequently used files, such as PDF, BIMx or MOD files. While normally the two BIMcloud components are continuously synchronizing between each other, in certain cases we need to manually s...
  • 5992 Views
  • 0 likes
  • 0 comments
Related versions: v18 and newer Backing up your BIMcloud is essential to avoid data loss and minimize the time needed in case of a disaster recovery. Your backup can also be used for moving the Teamwork Projects and Libraries or even the entire installed application onto a d...
  • 13626 Views
  • 0 likes
  • 0 comments
Related version: 21 The mains steps are the following: Choose a machine or machines to serve as the new host(s) for the BIMcloud Install BIMcloud software on these machines and update them to the same patch level as the original BIMcloud Move the backup from its archived sto...
  • 6498 Views
  • 1 likes
  • 0 comments
Labels
