2011-09-22 09:35 PM
2011-09-22 10:57 PM
2011-09-22 11:35 PM
yukioMishima wrote:Sort of. As far as 'much the same as now', if you mean just working within your office and possibly taking a project away on a laptop and coming back to send/receive - then yes, you can still work that way. It DOES require installing and using the BIM Server, but installing BIM Server for an in-house only network requires almost no thought. Things only get complicated when trying to access the server remotely (over the internet) which is a functionality that you don't have at present anyway with TW1 - so if you're happy with your current workflow, then setup for 15/TW2 is pretty easy.
(i assume you can still work in TW in much the same way as we do now... or is it BIM server or nothing?)
2011-09-23 12:14 AM
2011-09-23 12:41 AM
2011-09-23 01:13 AM
