using a tethered 3g connection w/ Bim server
anyone know if it is possible to use a tethered 3g connection w/ iPhone.
I am using tether.com's (http://help.tether.com/home) HTML 5 solution.
cannot seem to connect to Bim server; usually says "offline"...
speeds are way slow; but I have usually have the latest local version of the file, so I should be able to send and receive what ever small amount of data.
just want it so I can work on ferry going to Bainbridge Island, WA.
is it maybe a Bim server trait that prevents?....just dunno
3 Replies 3
Why dont you use a Travel Pack?
Save a Travel pack before you leave office, work on the Travel Pack on the ferry, then next day send & receive changes to/from the BIM Server.
You only need to make sure you reserve everything you need for your work before creating the Travel Pack.
ares997
It is most definitely possible. I have successfully tested all the way down to a tethered 2G connection. I recommend connecting to the BIM Server remotely from a fast connection to download all your data then you can try connecting remotely with the tethered connection. It is also good to create a separate identity that you can use for your remote connection.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
Yes, works fine remotely with iPhone.
