It is most definitely possible.  I have successfully tested all the way down to a tethered 2G connection.  I recommend connecting to the BIM Server remotely from a fast connection to download all your data then you can try connecting remotely with the tethered connection.  It is also good to create a separate identity that you can use for your remote connection.
	Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
