on
2016-10-07
11:30 AM
- edited
3 weeks ago
by
Koussay Farah
Related versions: v19 and newer
Make sure that all Archicad clients and BIMcloud / BIMcloud Basic components are updated to the latest build.
Archicad must be able to communicate with BIMcloud / BIMcloud Basic to provide Teamwork. To verify this, run the Network Diagnostic Tool from the Open / Join dialog or the Teamwork Palette. Verify whether all necessary ports are open and the server machine is available from the client machine.
Whenever possible, use wired connection to the network. Try turning off the wireless connection to make sure you can access the BIMcloud / BIMcloud Basic's computer over the network.
Try to open the Manager web user interface on the computer where BIMcloud Manager is installed. If it cannot be opened or if it seems the Server cannot be started properly, then check the Operating BIMcloud page for further help.
Make sure to use either a fixed IP address, a hostname or a Fully Qualified Domain Name (FQDN) for BIMcloud / BIMcloud Basic. For further information and recommendations, see the Network Requirements article.
On a client computer, verify whether the IP address is correct: in the Command Prompt (Windows) / Terminal (macOS), use the nslookup host command (where the host is the address of BIMcloud / BIMcloud Basic Server computer, without the port number).
Flush the DNS on a client computer by using the following command at the Command Prompt (Windows) / Terminal (macOS)
ipconfig /flushdns
sudo dscacheutil -flushcache
Double check that the names of the computers match their hostnames. Use Command Prompt (Windows) / Terminal (macOS) and run the hostname command. Compare the result with the name of the computer - the two names must be the same.
Do not use special characters in the server computer's name. A valid hostname can include letters (a-z, A-Z), numbers (0-9) and the hyphen (-) characters.
Avoid using space characters in file servers' name, and avoid some special characters in file names, libraries or library parts. For example: '', '/', ':', '*', '?', '"', '<', '>', '|'
Antiviruses, firewalls, backup or any other monitoring applications (e.g. Windows Search, macOS Spotlight) tend to scan all files in real time, which can cause huge performance issues on the server side. Turn off file indexing and add the Projects and Attachments folders to the exception list in your antivirus / firewall settings.
Similar to the server side, monitoring apps can interrupt the communication between Archicad and BIMcloud / BIMcloud Basic. In the settings of the above-listed applications, add Archicad and its folders to the exception list. Make sure to schedule 3rd party backups to run outside of working hours.
Make sure to add the BIMcloud / BIMcloud Basic address(es) to the bypass list.
Make sure that the reverse proxy is HTTP 1.1 compatible, at least. Configure the reverse proxy's TCP connection timeout setting to allow long-time TCP connections.
If the BIMcloud Manager cannot be opened in a browser, try to reconfigure the Manager to use another port.
Delete the TeamworkLoginDataStore2.json file (version 19 and above). Locations:
C:Users<username>AppDataRoamingGraphisoft
System drive/Users/<username>/Library/Preferences/Graphisoft/
Please Note
Software and hardware issues in the network infrastructure can cause trouble as well. Make sure the driver of the Network Interface Card is up-to-date. Verify the hardware side: check network cabling and test the performance of the Network Interface Card by copying a large file to the server computer through the network.
If you still experience the above issue, please contact your GRAPHISOFT support representative. For the investigation Archicad FastLogger files and BIMcloud log files might be necessary.
