We value your input!
Visualization
3D Window Settings in AC21
derekjackson
I'm just starting to explore AC21 for the first time, having been working in AC19 for a few years.
I can't seem to find the 3D Window Settings dialogue to fix the dimensions of my 3D window anywhere. It seems to have been replaced by the 3D Styles interface, which has no info on the current pixel dimensions of the 3D window.
Where can I accurately define the dimensions of the window in 21? I rely on this for setting up accurate views for Photorendering, aligning cameras to photos for montages, etc.
Thanks,
Derek
Erwin Edel
Right click the tab of your 3D window and you can set the size (Set Window Size).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
derekjackson
Perfect, thanks!
Erwin Edel
You are also familiar with the Render Safe Frame? This will show which part of the 3D window will be rendered and has (sometimes) influence on what is rendered as well.
www.leloup.nl
Windows 10 Pro
