2025-01-13 03:37 AM - last edited on 2025-01-13 04:12 AM by Barry Kelly
Hi All,
Cineware by Maxon add-on has unexpectedly closed.
Archicad should be restarted".
If I change the photorender engine settings to "Basic Renderer" it works fine but the "Cineware by Maxon" crashes.
Running - macOS 15.2 Sequoia
ArchiCAD 6010 USDA Full intel based Mac
Thanks in advance
Andrew Lister
Operating system used: Mac Intel-based 15.2 sequoia
Solved! Go to Solution.
2025-01-13 11:12 PM
This is a known issue listed here: https://community.graphisoft.com/t5/Installation-update/macOS-15-Sequoia/ta-p/616173
There’s also a workaround mentioned, but I haven’t tested it since we’re still using Sonoma.
2025-01-13 10:50 PM
we're having this issue as well. We updated the office to MacOS 15.2 and AC27 6010 yesterday.
2025-01-13 11:12 PM
2025-01-14 12:23 AM
it worked it worked. You're a lifesaver, thank you so much. Much appreciated!!
2025-01-14 05:45 PM
solved the problem here, too. Thanks.
2025-01-29
07:00 AM
2025-01-29
08:17 AM
Is anyone else still having this issue? I'm still receiving this pop up.
I've tried restarting my computer and replacing the Cineware folder as suggested but I'm still getting either the above up or I'll receive the below notification. I even changed my security settings to allow the below but am still getting the notification that "Cineware by Maxon add-on has unexpectedly closed". Any one have a solution?
2025-01-29 08:03 AM
Did you replace the folder after you changed your security settings?
Can you security settings be made to ignore anything in the Graphisoft folder and not just that one file?
I have no idea if that will work, just trying to think of things you can try.
2025-01-29 10:17 AM
I tried replacing the folder again after changing the security settings and still no luck. I don't receive the pop up about redshift anymore but still receive the notification that Cineware has unexpectedly closed.
Don't believe there's anything else that the security settings were blocking but either way I turned it off so no apps/files will be blocked.
2025-05-06 04:58 PM
it does not work for me either... any new tips here?
