andrewlister1
3D issues - Cineware by Maxon crashes
Hi All,
I wonder if someone could help me with a problem I am having with rendering in 3D.
I click Creative Imaging > Photorender projection then a pop up window shows up saying
"Warning!
Cineware by Maxon add-on has unexpectedly closed.
Archicad should be restarted".
If I change the photorender engine settings to "Basic Renderer" it works fine but the "Cineware by Maxon" crashes.
Running - macOS 15.2 Sequoia
ArchiCAD 6010 USDA Full intel based Mac
Thanks in advance
Andrew Lister
Operating system used: Mac Intel-based 15.2 sequoia
1 Solution
vlahtinen
This is a known issue listed here: https://community.graphisoft.com/t5/Installation-update/macOS-15-Sequoia/ta-p/616173
There’s also a workaround mentioned, but I haven’t tested it since we’re still using Sonoma.
Go to post
11 Replies 11
Aaron Bourgoin
we're having this issue as well. We updated the office to MacOS 15.2 and AC27 6010 yesterday.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
vlahtinen
andrewlister1
it worked it worked.  You're a lifesaver, thank you so much.  Much appreciated!!
Aaron Bourgoin
solved the problem here, too. Thanks.
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
NikolinaO
Is anyone else still having this issue? I'm still receiving this pop up.
I've tried restarting my computer and replacing the Cineware folder as suggested but I'm still getting either the above up or I'll receive the below notification. I even changed my security settings to allow the below but am still getting the notification that "Cineware by Maxon add-on has unexpectedly closed". Any one have a solution?
Did you replace the folder after you changed your security settings?
Can you security settings be made to ignore anything in the Graphisoft folder and not just that one file?
I have no idea if that will work, just trying to think of things you can try.
NikolinaO
I tried replacing the folder again after changing the security settings and still no luck. I don't receive the pop up about redshift anymore but still receive the notification that Cineware has unexpectedly closed.
Don't believe there's anything else that the security settings were blocking but either way I turned it off so no apps/files will be blocked.
solvi
it does not work for me either... any new tips here?
andrewlister1
Hi there, I’ve started getting the same pop up window again.  Replaced the cineware folder again a few times but no luck.
Is there a new fix to this problem?  Anyone?
