2006-11-12 08:32 PM - last edited on 2023-05-11 02:43 PM by Noemi Balogh
2006-11-12 08:50 PM
2006-11-14 09:05 PM
2006-11-15 07:06 PM
chriszolezzi wrote:wow tx a lot
Good Luck. It can be a tricky thing to do especially if you want it to look right. The best way to do it from my experience is to know exactly where the picture was taken and how to translate the information from your camera into the computer. You can calculate the angle of the camera view cone fairly easily by setting it on a sheet of paper and marking the edges of the view and drawing lines.
Once you have all this information you can set up a camera in ArchiCad. This is important so you can go back to the exact location once it is set up. If all goes well you can set the sun angle to the proper day and time and your project will match the surrounding environment quite well.
2006-11-15 07:08 PM
2006-11-15 11:04 PM
2006-11-16 09:17 PM
2006-11-17 12:14 AM
2006-11-17 12:40 AM
