8" White CMU Texture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-02-24 09:31 PM - last edited on 2023-05-11 12:59 PM by Noemi Balogh
Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-23 12:47 PM
TurboGlider wrote:So did I.
I've edit my next post with some idéa about your problem.
I will check out reference lines etc. Seems like a good place to start.
Thanks for your interest. Have a good weekend.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-23 01:06 PM
Can you post your Internal Engine Texture settings? I might have solution for your problem.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-26 12:07 AM
The fill pattern "stonework" is simply horizontal lines at 200mm centres. Origin is 50mm below front corner as indicated by red cross. (50mm setdown to suit our standard NZ veneer detail).
I appreciate your help, folks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-26 07:42 AM
And ofcause the "Set direction" under Align 3d Texture? (try to rotate 180 degress and 360degress, in this type I have recognize that 360 isnt' the same as 0 degress )
Your screenshoot looks exactly like a model that could make those things happend.
Sometimes ArchiCad's render don't handle this situations very well if you have displacement maps on, try to set it off.
(All of this is try'n'error tests made by me , this is not official Graphisoft solutions)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-26 05:30 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-26 08:25 PM
tigr wrote:True, Texture Space could .... it up too.
It is obviously LW that mess with the texture origin and you should focus on the settings there, my bet is the "Texture Space". Set it to "none" and try again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-30 03:14 AM
I've been away for a few days, in the meantime the design has changed slightly. Right hand side bay window has been removed, and left hand side one made full height, quoins added at corners (yes I know they look too low at the moment). And as if by magic, texture now aligns over the full wall face, and at the junctions. Turned off the texture Space setting just to make sure though.
I wil keep all this in mind for the next time this happens.
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-03-30 08:28 AM
- « Previous
- Next »
- « Previous
- Next »
