alemanda
AC21 - Navigator for 3D View
Mini map where to place camera and target is missing
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
1 Solution
alemanda
I caught the problem.
I'm working in a rotated view.
3D navigator view is not rotated so when I zoom in I lose the connection between the two views ..
If I revert back to a normal (not rotated view) everything is fine.
I think it should be treated as a bug or misfunctionality.
AC27 latest hotfix
Win 11 Pro 64bit
Go to post
9 Replies 9
Try this.
ALT click in the preview to plac the camera.
SHIFT click in the preview to place the target.
alemanda
Thanks Barry,
I knew that already ..
the issue is that I don't see the plan (in wireframe it was) as before ... it's just a blank space
AC27 latest hotfix
Win 11 Pro 64bit
Stress Co_
Go back to your plan view and zoom out/pan to
the desired area of concern.
Then go back to the 3D Settings.
EDIT
I see by your screen shot that you already did.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Try switching to Perspective and then back to Parallel?
I am not seeing this problem so it is hard to say.
Or the old IT fallback - re-start the machine.
Lingwisyer
Guru
No idea what units you're working with, so might 40k units be too far from your site that it's zoomed out the plan?
Ling.
alemanda
AC27 latest hotfix
Win 11 Pro 64bit
Well spotted.
I have marked this post as 'solved'.
You will need to report it to your local distributor if you want it to be acknowledged by Graphisoft.
They may see it here but there is no guarantee.
Stress Co_
Misfunctionality I'd say.
The "Navigator Preview" palette matches the 3D preview.
"Navigator Preview" shows how the view (visible screen) is rotated.
Link
That's weird for sure. The Navigator Preview has a Redraw option. I wonder if that affects it.
Otherwise perhaps switching the Work Environment profile may do it?
Link.
