ā2014-07-19
05:18 AM
ā2023-05-11
12:54 PM
Noemi Balogh
ā2014-07-19 05:36 AM
ā2014-07-20 04:49 AM
Karl wrote:I am using Archicad EDU 17. (I don't know if you've answered this yet) but will the stone texture show the stones actually poking out or will it only be 2D texture like a wallpaper?
There are a variety of stone surfaces (photo texture, as shown, for renders as well as corresponding 2D fill/hatch) in your library. One looks almost exactly like the stacked stone in your photo, as I recall.
Which version of AC are you using... presumably EDU but 17? 18?
ā2014-07-20 08:57 PM
Pro wrote:In 17, the bump map will create shadows as if the stones are 3D... but the corners, or the face as viewed at an angle, will clearly be just a flat 'wallpaper' as you call it.
... will the stone texture show the stones actually poking out or will it only be 2D texture like a wallpaper?
ā2014-07-21 01:53 AM
ā2014-07-21 01:56 AM
ā2014-07-22 01:58 AM
Karl wrote:Yes! That is exactly what I want. I just cannot seem to find it when I'm applying a texture to the wall. I have the EDU version could that be a reason why I cannot find it?
Here's a quickie with the CStone 01 texture on a wall in 17. The texture image is low res and not the best at closeups...but notice the perfectly vertical edge line at the wall edge to the right, typical for AC 17 and earlier...
ā2014-07-22 02:34 AM
Pro wrote:Localized (by country) versions have differing content. I'm not sure if EDU does as well.
