Add extra camera on existing path
Hi, I am struggling to add an extra camera position along an existing path between two other cameras.
I found this; http://archicad-talk.graphisoft.com/viewtopic.php?p=171681
and tried it. But my new camera is just being added at the end of the path still! What am I doing wrong? Thanks.
2 Replies 2
David Maudlin
Daniel:
Yes, the link's suggestion did not work (on AC19). What did work (again, AC19): in the 2D Window is to select the Camera before the one you want to add, then Drag a Copy of that Camera, it will be added after the original Camera in the path.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Wow, can't believe how simple that was! Thank you! I couldn't see that in the help sections for fly-throughs. Thanks again.
