Visualization
Add light grey fill as graphic override while maintaining composite fills
ELEVATE
How do I set the graphic override for new wall construction to show a light transparent grey shade over NEW walls while maintaining the composite fills.   When I set the fill to 15% it replaces all the composite fills.  Thank you!!!    🙂
DMD
Try by not overriding the actual fill - leave that off.
Just override the background pen colour for the cut surface.
1 REPLY 1
Setup info provided by author
