Visualization
Aligning Textures
Nik,
set origin for texture for each wall to same base point, in 8.5 open 3D window select walls >Edit > Align 3D texture > Set Origin - click base point on corner.
regards,
Scott Boyd Turner
Dwight
The ATKIQuikFixâ„¢ for this is to create another material with texture mapped at 90 degrees to the original. It still won't be originated correctly [unless by coincidence] but it will run the right way at least.
Dwight Atkinson
11 REPLIES 11
Nik,
regards,
Scott Boyd Turner
Dwight
forget?
Dwight Atkinson
Hey guys.. The above solution didn't help me here.. I am stumped!
Thanks
Eliminate eave?
Aussie John
im guessing the eave is a separate library part. Unfortunately set the origin doesnt apply to objects. The 3D script needs is the coor and vert commands - Good luck as the manual is fairly unhelpful in this.
The simpler option is to extend the roof and SEO the roof part of the eave
Cheers John
[/size]
Dwight
Dwight Atkinson
Dwight
Or make an eave element that doesn't include the roof portion, letting that be continuous with the actual roof....
Dwight Atkinson
Thanks Guys for the help... Well, I tried all options with the part.. No luck.. The new material idea would drive me nuts being slightly off even if only I knew (and Dwight.. ) So I just extended the roof overhang.. thankfully it stays "in front" of the Eave part..
The Author must have tested this? I tell you slowly I am realising it is best to do all possible with native AC tools and Libraries..
Thanks Again!
undefined
May I ask another.. what is this line with the little tick mark on all my roof planes?
