Visualization
Alpha channel renders black
Tendenz
What am I missing? I do i the same way all the time - sometimes it works, sometimes it doesn't.
I create a material with alpha channel, it looks correct in both material settings and 3d window, but renders black.
I've tried with PNG and TIFF, and with and without Physical Render.
Help?
iMac OS X 11.6
2,3 GHz Intel Core i9, 16 GB 2667 MHz DDR4
ArchiCAD 25
Paopao
Same thing happening to me. All my glasses render black!
There is a supposed way around this here http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/texture-overwrite-fails/ but it doesn't work for me somehow, see if it does anything in your case.
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
Tendenz
I'm having this problem again...
Physical renderer is on. What's wrong?
iMac OS X 11.6
ArchiCAD 25
Erwin Edel
If you do not have enough layers of transparancy set up, you will end up with black I think.
Try rendering one single element with the surface. If you see transparancy there, the surface settings are ok.
In cinerender go in to 'detailed settings', scroll all the way down to options > general options. Check the settings at Ray Depth and Reflection Depth, you'd really want them to be at something like 12 or more depening on the amount of layers of transparancy there are in your view. It takes 3 'bounces' of the rays to get through a plate of glass (2 layers) and show what is behind it. Flat alpha channel textures probably count as 1 layer. So let's say you have a window (2 layers) and some alphachannel texture sitting behind that window, you'd need to have at least a depth of 4. However, quite often things overlap, so I find 12 to be a nice safe number that still gives reasonably fast render times and doesn't mean I need to remember to change the settings when the model changes.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
