Animating an Object
Can we animate an object modelled in ArchiCAD? (Like animating a vehicle or a car with all the tyres moving )
3 Replies 3
stefan
Only if the object is scripted that way. What you want to do is almost impossible in ArchiCAD, but fairly straightforward in applications such as 3ds max or Cinema4D.
So if you script your own GDL objects, you can add some functions to react on the current framenumber, but that's about it.
Archicad-user since 1998
my Archicad Book
Stefan,
Thanks a lot for your early response. I was really very eager to know if it is possible in ArchiCAD.
I shall keep posting on few more topics in future.
Djordje
sakshi wrote:
Stefan,
Movement animation is also very easy in Artlantis Studio.
The movement in Archicad has been discussed around here, and involves scripting the object so that it is sensitive to the frame count. Once upon a time, there used to be a free Porsche 911 at Objects On Line, that was scripted for animation - and it is an excellent example of how to do it, too! If you can find it somewhere, that is ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
