Visualization
Applying a 'Logo Texture' to a round billboard.
muzedesigns
Hello Again..
I am trying to texture map a Logo/Crest/Image onto a round element..
Right now I trying to place it on a cylinder object which is rotated to look like and O Front on to the Elevation. But am not being very successful in my attempts as the texture seems to be obscuring despite being on the flat face of the cylinder..
I have created a new texture with the image and am then using the Offset Class to move it around with S and T Co-ordinates..
Is the a circular billboard that exists or a easy way to do this?
So I am trying to place a material to sit centre on a round flat vertical signage element.. which is then place flat on a wall..
Sorry if this is confusing!
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
13 REPLIES 13
muzedesigns
Here is an example of what I am trying to do..
There are 7 separate locations where i need to place the same sign.. I have kept all a consistent size excluding to that are a scale down versions..
Hopefully that may make my description a little easier to decipher..
Chrissy Avramidis
Create Alpha channel in the image of the logo (a white circle in a black square).
Use the of library part "Picture".
muzedesigns
Thank you very much for your response Valery.. Your solution works perfectly! Cheers!!
Chrissy Avramidis
It pleases me
Good luck, Muze!
Djordje
Or you could use the billboard function of ArchiFacade
Or you could render in Artlantis ... do yourself a favour and try it!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
muzedesigns
Thank you every one!
Do myself a favour and try Artlantis? .. i specifically need this applied for a flythrough animation.. I have just been adding it in photoshop for stills..
Does Artlantis do both now? (back when i had it it was just for single shots)
Thanks again all for showing an interest! you are all a great help!
Chrissy
Chrissy Avramidis
There are now 2 versions of Artlantis:
Artlantis R just does still shots whereas Artlantis Studio does flythroughs, VRs etc...
Studio is a bit more expensive.
If you are applying alot of graphics to things, I find it way easier + quicker than using lightworks.
muzedesigns
Thanks Tom - I just looked it up as well.. I have been living in the dark ages apparently.. Silly me!
Chrissy Avramidis
Or get your hands on one of the previous Artlantis (version 4._ something I believe) and have the best of both worlds....stills and fly-throughs
too bad we cant save to older Artlantis file formats....I'm sure there's a workaround though.
