ArchiCad+Texture v Maxwell
using ArchiCad/CineRender + good quality texture library could result good image near something like maxwell output?
3 Replies 3
Steve Jepson
No.
Erwin Edel
I don't think the cinerender physical renderer will be on par with a dedicated engine like maxwell, however: there are a lot of cinema 4d tutorials you can find to get you along, the preview is quick to give a good indication of materials/colour, it works fine for still images and there is no extra cost for getting a seperate engine.
Also kind of depends on your platform. MAC is kind of limited to high end CPU rendering, I'd say, whereas GPU rendering seems quite popular for windows machines.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
runxel
I think actually the biggest disadvantage is the missing possibility to output channels.
But still, Maxwell is an unbiased renderer and treated properly it will produce pictures with the highest quality.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
