Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Visualization
Archicad 26 Photo Rendering realistic grass not working on ground 0 level
George_B
Can someone explain why the grass doesn't come out on the ground level in Archi 26 ?
I have been using the realistic 3d grass in the previous ArchiCAD versions. It should work ok.
However, it seems the grass pop up under ground. you can see the image grass coming out below the edge.
If I lift whole plane to the air, the grass begin to show up. can someone explain?
Seems to be a bug.
https://community.graphisoft.com/t5/Design-forum/Upside-down-3D-grass-in-cinerender/m-p/368009
George_B
I hate the bug >.<  it is pain in the ass. I have just tested the grass plane above 1mm from G level. it works.
