jamespage11
Artlantis - Need more polygons!
What's going on here? I drew some vanities for a bathroom - they're custom profile walls rotated around a very small radius, saved as embedded objects and then set into separate custom profile walls for the counters with a subtraction SEO. They look fine in Archicad, as you can see in the screen shot below, but when I import the model into Artlantis they come out with a ridiculously low number of polygons. Luckily the finish I want is a streaky, thick glaze so I was able to disguise it a little, but it still looks terrible. (Rendered image to follow) Anyone know how to fix this?
Cape Town, South Africa
AC 24
Windows 10
Intel Core i3-4160 3.6GHz
NVidia GeForce GTX 1660 SUPER
11 Replies 11
Dwight
Yes.
Smooth the polygons - Material Dialog.
Buy my Artlantis Attitude book for ALL the answers.
Dwight Atkinson
jamespage11
Krippahl and Dwight, thanks so much! That material smoothness slider is magic! I can't believe how easily it works! And it doesn't even seem to slow render speed down too heavily.
What does the merge vertices function actually do? It doesn't seem to make a difference whether I do it or not, and it gives one of those scary warnings that it can't be undone..
P.S. Dwight I might actually do that. I seem to have hit a bit of a ceiling in improving my renders with Artlantis. They're looking pretty good I'd say, but they're missing a lot of what makes a truly professional looking image, and the Artlantis forum's not really much help once you've grasped the basics of the software..
AC 24
Windows 10
