Artlantis, ground plane?
When working in Artlantis 3, is there an option to turn on an infinate floor plan that extends to the horizon when using heliodon light setting? I dont always want to import a slab or using the basic shaps in Artlantis.
Just to say.... Ive just upgraded to Artlantis 3 and so far its been a joy to use, especially when working with extra shaders. Not sure if Im just getting used to using artlantis but Art3 feels much more fluid and easier to get good results with than 2. With the archi plug in, the work flow between artlantis and Archicad is very good.
merci
Lisa
3 Replies 3
Eduardo Rolon
In the Scene Tab click on the Scene Information Button. It should be hiding there.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
...which is also the shortcut cmd-I (Mac) / ctrl-I (Windows). You will use it a lot. 😉
thank you guys
why is it hidden there and not with the other enviroment options????
