2014-08-05 07:53 PM - last edited on 2023-05-11 12:02 PM by Noemi Balogh
2014-08-11 03:50 AM
2014-08-11 04:00 AM
2014-08-12 12:15 AM
Barry wrote:I was modeling in ArchiCad 16 that imported to 18.. Is that the problem?
Try using a different pre-set scene in the render settings.
Otherwise try adjust the light settings for sun, materials and lamps.
Also play around with the sky settings in the Environment section.
Using the pre-set scenes is the easiest unless you know what you are doing.
2014-08-12 03:42 AM
2014-08-16 08:10 AM
2015-05-19 04:47 AM
2015-06-12 03:37 PM
2015-08-07 02:53 AM
millarm wrote:This worked for me too.
i was getting the same thing happening. i opened another instance of archicad and pasted my houses in there and it worked fine.
