Can I save more than one Parallel Projections to Artlantis
I´m trying to be more fast on my process to make renders with artlantis. What always I do is on archicad save to artlantis, and then on art, create more cameras, then assign the parameters of angles, height, etc.
So my question is when I save on archicad to artlantis, by default it appears one camera, is there any other way to save on archicad more cameras, then save to artlantis? I allready try it on AC in the navigator, but maybe I´m doing something wrong.
Thanks
__archiben
not really used art•lantis for a while, but i always thought you had the option to export all cameras (and lights, etc.) when you save out? no?
otherwise, you could set up a publishing set from archiCAD and publish each view with one click. i know that this creates more art•lantis files to work on, but after working on the first, each subsequent camera shot could be opened 'with reference file' in art•lantis . . .
best i can think of if all of the cameras aren't exported in one hit . . .
~/archiben
b e n _ f r o s t
Ben, I saved the files separately to artlantis, one for each camera, then on ART, I open with reference. Thanks for your idea. What you suggest me I don´t understand it very well, because I don´t know now how to publish, yet What I only know is to save it jpg file, on the navigator, I need to practice more that area,
Regards,
David
