Changing the 3D window size changes saved views
Hello all,
I'm sure I'm missing something obvious but...
I have read various posts about batch rendering (saving views and using the publisher) and I have managed to get it to work successfully.
Something that I don't understand though is that if I subsequently change the size / proportions of my 3D Window as I work then when I try and batch render through the publisher again the crop of all my images will be different.
How can I be certain that every time I click Publish the images will be identical without needing to worry about how I've left my 3D window?
Some of the images are parallel projections for which I don't think it is possible to set up a camera (if that matters?).
Many thanks,
Nick
Archicad 18, 7007 UKI FULL
Mac OS 10.11.3
0 Replies 0
