‎2016-04-20
06:11 PM
‎2023-05-11
11:40 AM
Noemi Balogh
‎2016-04-21 03:09 AM
‎2016-04-21 11:42 AM
‎2016-05-04 06:24 PM
Barry wrote:
Have you tried the standard 'Brick - Common Flemmish 18' surface?
Check to see if you have it.
I am not sure if it is standard with Archicad or part of the 'Additional Surface Catalogue' for SSA users.
It doesn't use the brick shader at all - probably because it can't do what you want.
‎2016-05-04 06:25 PM
Erwin wrote:
I am not sure about your local market, but in NL most of the larger manufacturers of bricks offer custom texture generators with fairly large (as in number of bricks large) textures, so the repetition isn't that bad.
Wienerberger, for example, (I think they are General Shale in US) has such an option here.
This is all in dutch, obviously, but just to get a general idea:http://wienerberger.nl/producten/agena-hv#collapse-collapse1366232660562
