‎2014-07-29
01:00 AM
‎2023-05-11
11:45 AM
Noemi Balogh
‎2014-07-30 10:51 PM
‎2014-08-04 03:00 PM
‎2014-08-07 06:40 AM
‎2014-08-07 09:28 AM
‎2014-08-14 08:32 AM
Anestis wrote:I do find it little tricky to balance the setting to get best quality without increasing the render time.
Glad you sorted things out!
If you are using IBL (image based lighting with HDRIs) always check the gamma value and if there is a brightness slider,don't be afraid to bump it up a bit.
From my personal experience I can tell you that HDRIs are an extremely usefull tool, if you use them correctly, render times are increased though.
3D grass always add immensely to the realism but don't go crazy with the density values. Try using a compination of grass textures & 3d grass.
Looking forward to seeing some of your work!
Cheers!
